Avid will not play footage on some clips however sound still plays
Nathan Davies-Burke
on Apr 19, 2012 at 11:08:06 am
Hi there
Ok heres what im doing
shooting on Canon 305 SS cards
Importing the date via shotput pro onto two drives A & B
B is my back up drive
Once in there I check using a utility prog
Then hook up to avid, as the footage is going to an edit suite to be edited into a 6 part doc series
I link to AMA Volumes, drage the clips from the card in, into a dated folder with directors initials also, then I highlight and consolidate to drive B to send the MXF file to the editors
HOWEVER
when later looking back over the clips I have backed up through avid it appears that a few clips on each card only play their sound through the avid, however when paused the clip image does appear...
all the other clips from the cards play fine, just some do this...both from playing from my rushes folder on drive A and my B drive... can this be because I have dropped said cards into their directors folders on both drives...
please advise guys
thanks in advance
