How to Highlight a Sequence in Bin? MC6
sandy shapiro
on Apr 17, 2012 at 1:31:45 pm
How do you highlight or color label a sequence in your bin using MC6? I once had a label column to the right on the sequences, but it disappeared after I changed from "statistics" to "film" and back.
Michael Hancock
Re: How to Highlight a Sequence in Bin? MC6
on Apr 17, 2012 at 1:44:38 pm
Go to the fast menu in the bottom left of your bin and select Choose Columns.
Activate "Colors".
Save your bin layout and you won't have to remap it every time.
Michael Hancock
Editor
sandy shapiro
on Apr 17, 2012 at 1:55:47 pm
Perfect. Thanks again!
Ed Cilley
on Apr 19, 2012 at 8:37:32 pm
Sandy,
I also like to use the Comments column for adding details. It doesn't show up unless you already have a comment. So here's what I do.
Change view to "Script" and name a note in the box. Then go to the Columns view like Michael mentions and you will see Comments. After hitting OK, you can move columns around so Comments appears right after Color, or any other column. Then Save it and call it whatever you like. My favorite is "Don't Click Here"
_________________________________________________
Anything worth doing at all, is worth doing well.
- Philip Dormer Stanhope, Earl of Chesterfield
