I upgraded to 6.0.1 and I'm missing tools!
Matt Walker
on Apr 17, 2012 at 7:31:45 am
Hi all,
I am using 6.0.1.
When I go to Windows>Workspaces>Color Correction my Color correction tool in nowhere to be found!
My final is due Friday!
I'm using a Mac Pro 2x2.4 quad cores
48 Gb ram
running lion 10.7.3
Michael Hancock
Re: I upgraded to 6.0.1 and I'm missing tools!
on Apr 17, 2012 at 2:14:18 pm
How many monitors do you have and how are they set up? I had the same issue - this is how I solved it.
If you have two monitors and monitor 1 is on the right, go to your System Preferences -->Displays-->Arrangement and make sure the menu bar (or whatever it's called) is on the left monitor. Mine was on the right. When I swapped my monitors so it was on the left my Color Correction workspace showed up. See pic below:
Michael Hancock
Editor
Matt Walker
on Apr 17, 2012 at 3:51:21 pm
I do have two monitors. I tried the switch, while avid was running and while it was closed, no luck. I just tried a clean reinstall too, nothing.
