Offsetting Picture within a frame
Tom Carlson
on Apr 6, 2012 at 1:20:59 pm
I was wondering if it is possible to offset a picture within a frame on exporting. I have designed a menu for a Blu-ray disc as a video track and when displaying the final product on my television monitor, the entire frame seems to be about 50 pixels too far to the left. Is there a simple way to move all layers of a sequence say 50 pixels to the right? I would then want to fill the left side of the frame with black pixels to match the background. I'm trying to avoid having to go back to my source material and shift it before inputting into the Avid.
Tom Carlson
John Pale
Re: Offsetting Picture within a frame
on Apr 6, 2012 at 2:05:41 pm
Put a 3D Warp Effect on an empty layer above your sequence. adjust as needed. It will move everything below it. Depending on the complexity of your sequence, you may have to render.
Tom Carlson
on Apr 6, 2012 at 3:26:16 pm
Thanks, John. Sounds simple enough.
Tom
