Creating DVD
Anna Wysocka
Creating DVD
on Apr 3, 2012 at 11:04:55 pm
I have MC 5.5 and I would like to make a dvd that would contain my film.
I have a project that was shot on Canon 7d and GoPro
mov files have been linked to AMA then transcoded to DNxHD120, mp4 imported
So far I have highlighted my sequence in a bin and send to dvd authoring - i got message that sequence is set to AMA, therefore my export is cancelled
>send to > encoding > sorenson squeeze, similar story
I have checked my sequence and i found that all clips on timeline are transcoded DNxHD120 clips- I am quite new to AMA subject and I might missed something about them.
I have exported my sequence as fast export quicktime pal, imported in sorenson squeeze and picked dvd pal 25 preset, so i could give my director copy for viewing. I am sure that I am doing something wrong or I am just not aware about something simple and obvious.
Ricky Barrow
Re: Creating DVD
on Apr 4, 2012 at 11:28:00 am
My knowledge is limited but I will explain our workflow and perhaps this will give you something to consider. In MC I first link AMA, then, before editing into a sequence, I transcode to Avid DNxHD media. It sounds like your sequence is still looking at AMA links instead of actual transcoded media. When going into Encore, I export a QT ref. file of my sequence (which is all transcoded media) I drop the QT ref into Encore and let Encore do the transcoding for DVD. I haven't experienced the issue you describe. Avid MC and Encore are on the same computer (PC for us). From what you describe, I can only say to double check that you have no AMA linked footage.
Ricky
Anna Wysocka
Re: Creating DVD
on Apr 4, 2012 at 7:55:13 pm
I was more or less doing the same thing as I have also transcoded everything to DNxHD. I will check all clps again. Thank You
John Pale
Re: Creating DVD
on Apr 4, 2012 at 3:40:50 pm
don't waste your time trying to debug it. It' will just give you a headache.
Just do a video mixdown of your sequence. duplicate the sequence and replace the video with the mixdown. If you still can't export, do the same with the audio.
Anna Wysocka
Re: Creating DVD
on Apr 4, 2012 at 7:46:15 pm
Thanks for a quick tip. I will still try to figure out what i have done wrong but you saved chunk of my day today.
John Pale
Re: Creating DVD
on Apr 5, 2012 at 2:39:46 pm
I don't think you did anything wrong. It's just flakey. It'll work fine sometimes, other times not...usually when you are in a hurry :).
That's why I said to not bother debugging. Something probably didn't transcode..or Avid thinks it isn't transcoded, even though it is.
Usually mixing down will do the trick.
