fastest export file type
Peter Groom
on Apr 2, 2012 at 12:34:50 pm
Hi all
which is the fastes to export file type that will then be acceptable to go into adobe encore for blu ray authoring.
H264 takes for ever (it was down to 20 hours when i quit)
advice needed.
Cheers
peter
Post Production Dubbing Mixer
Job ter Burg
Re: fastest export file type
on Apr 2, 2012 at 12:50:29 pm
Check the "Same As Source" box. No re-encoding, just a copy of your edit in a QT container. Fastest way by far. Let Encore encode for BD from that. On your Encore system, you will need to have the Avid QT codec installed. The Avid QT codec is a free download at avid.com/codec.
Mike Jeffs
on Apr 2, 2012 at 9:20:01 pm
If you are working in a AMA workflow, then the same as source won't work as Avid doesn't know what the source is.
Mike Jeffs
Video Coordinator
BYU-Idaho
Michael Hancock
on Apr 2, 2012 at 9:24:36 pm
[Job ter Burg] "No re-encoding, just a copy of your edit in a QT container. Fastest way by far. "
If he's not working with any AMA material, wouldn't a Quicktime Reference be faster?
The Same As Source has the benefit of being transferable across systems and archivable, though.
Michael Hancock
Editor
Job ter Burg
on Apr 2, 2012 at 9:43:40 pm
Right on both accounts. I was assuming a self-containing result.
George Angeludis
on Apr 3, 2012 at 9:46:49 am
SAS with Avid Codecs. If you work with AMA you have to transcode first.
This is again the fastest method. QT ref is a little bit more faster (and this depends also)
but you can't use the file elsewhere.
Director Editor
Peter Groom
on Apr 4, 2012 at 2:10:01 pm
HI Job.
Is it your understanding that encore should take a qt ref file?
If that qt ref file links a video mixdown file in avid, will that still work in encore. Are there any length restrictions you know about. the hd timeline is 2hr 32 mins.
and lastly, in encore , if i set the compression to automatic will that crunch the video down by the correct amount to fit on a 25gig BD.
Peter
