AVID transcode walkaround
Nicolas Servide
on Mar 28, 2012 at 4:21:27 pm
Hello,
I am working in a long documentary. I am importing the raw files (straight from the canon C300) using AMA, and then transcoding into DNxHD 36 AVID codec.
But it takes for ever!
How necessary is it to transcode all the material?
I heard that playback will suffer if I just link everything with AMA (about 50 hours or more)
Michael Hancock
Re: AVID transcode walkaround
on Mar 28, 2012 at 4:28:02 pm
Why are you transcoding? You should be able to consolidate (which is essentially a file copy with a checksum). The C300 footage shouldn't be that heavy on your system.
Dylan Reeve has a nice video on how to bring C300 footage into Avid:
http://vimeo.com/groups/c300/videos/38909217
Michael Hancock
Editor
Nicolas Servide
on Mar 28, 2012 at 4:46:38 pm
Thanks Michael!
But wouldn't consolidate take as much time as transcoding?
I will check that video.
Best!
Shane Ross
on Mar 28, 2012 at 4:49:51 pm
Consolidating is copying, transcoding is recompressing.
Shane
Little Frog Post
Daniel Frome
on Mar 30, 2012 at 12:25:26 pm
We're doing a show that shoots 15 hours of C300 footage per day. We consolidate (not transcode) with relative ease. We can consolidate 1 shooting block (40-50 hours of footage) in one day.
Don't transcode... DNx36 isn't that much smaller than the full rez (50mbps) material. Waste of time.
Nicolas Servide
on Mar 30, 2012 at 12:30:12 pm
Thanks guys!
Great help :)
Nicolas Servide
on Apr 3, 2012 at 11:06:44 am
Thanks for the tip, Daniel.
It's indeed much faster.
But sometimes I have issues to link back to the original "camera files", and I am afraid that this will cause problems in the online.
What I do:
1. Import/link with AMA
2. ALT+Drag files to a new BIN
3. Consolidate to my Avid MediaFiles
But when both bins are open, some files links to different locations.
Is this normal? Would you suggest a different workflow?
