Incredibly strange file naming.
Scott Davis
on Mar 25, 2012 at 2:29:28 pm
I have some media which I am trying to transfer to another system. All this material was generated on a NanoFlash using the XDCAM codec at 100Mbs. To get it into the Avid I AMA linked and then consolidated.
Half the interview is fine and relinks fine on the other system. Half does not. I took a look at the Avid media file and there are a bunch of Asian characters in the names of the clips that will not relink. I've attached a picture of the Avid media file.
Scott Davis
View Scott Davis's profile on LinkedIn
Shane Ross
Re: Incredibly strange file naming.
on Mar 25, 2012 at 4:44:58 pm
Common issue:
http://community.avid.com/forums/p/102873/593239.aspx
http://forums.creativecow.net/thread/45/883016
Can't find if this has been solved though. Which version of MC are you running?
Shane
Little Frog Post
Scott Davis
on Mar 25, 2012 at 5:38:55 pm
Shane, I'm currently running v6.0.1 but these were created in 6.0. Interesting thing is that some clips recorded at the same time have the characters and some don't. The ones with the characters are giving me relinking issues.
Scott Davis
Shane Ross
on Mar 30, 2012 at 12:58:37 am
Sorry...this is a bug that has no resolution as of yet, apparently. STill being worked on.
Best bet would be to trash those files, and reimport...transcode.
Shane
Little Frog Post
