Freeze Frame greyed out in drop down.
Cammie Noel
on Mar 20, 2012 at 10:13:09 pm
Have made progress, have MC tutorial book ect. Have followed instructions for doing a freeze frame but when i reach the clips pull down menu after following steps(mark in / match frame,) then the function for freeze frame is greyed out. Again any help is much appreciated.Cheers
Scott Cole
Re: Freeze Frame greyed out in drop down.
on Mar 20, 2012 at 10:24:04 pm
Typically Freezeframes can only be made of clips, not from a sequence. Match to your clips and then try the freezeframe. If you need to make a freezeframe of an effect in a sequence, do a mixdown and then load that mixdown into the source monitor, park on the needed frame and create your freezeframe.
M. Scott Cole
Senior Post Production Editor
60 MINUTES
CBS News, NYC
sc6@cbsnews.com
mscottc@comcast.net
steve knattress
on Mar 23, 2012 at 12:57:14 pm
After match framing you are selecting the source window before going to the clip pull down window?
Note here, you can also select the type of freeze if you have interlaced material.
You can also add a zero speed time warp effect, at a given point.
This is good if you are trying freezes at different places on your clip.
