3D Stereoscopic EDLs are always Out of Sync?
David Steiner
on Mar 19, 2012 at 9:08:08 pm
I tried this on two different projects with different sources and workflows, and there's a problem, probably with EDL Manager?
1) I have L/R master clips
2) they have same synced TC, but not same starting TC (record button wasn't pushed at the same time on two cameras)
3) I create the S3D clip, syncing on TC
4) I edit it - everything works in MC6.
5) When I output the EDL, EDL Manager gives a different TC
003 LE__0003 V C 14:38:11:00 14:38:21:00 01:00:31:09 01:00:41:09
* FROM CLIP NAME: LE__0003_01
003 RE--0004 V C 14:38:16:17 14:38:26:17 01:00:31:09 01:00:41:09
* FROM CLIP NAME: RE--0004_01
The right one is the left one (source 11:00, not 16:17). and the difference: 16:17-11:00 is exactly the difference between the start TCs of the two:
LE__0003_01 Start TC 14:37:14:10
RE--0004_01 Start TC 14:37:20:02
in EDL manager, I chose "START TC" as source TC, because that's logical and that's the default, and none of the other works.
Anyone managed to export L/R EDLs from MC 6?
I'm trying to conform in Resolve. Resolve works perfect, except EDL manager feeds him false info :)
David
Michael Phillips
Re: 3D Stereoscopic EDLs are always Out of Sync?
on Mar 19, 2012 at 11:40:48 pm
Can you zip the bin with the sequence or a sequence of just those clips and send it to me to look at? If so, send to:
michael(at)24p(dot)com
Michael
Michael Phillips
David Steiner
on Mar 20, 2012 at 12:45:18 am
Hi Michael,
I sent you a small bin with just:
- two LE/RE (left/right eye) 2D master clips of a real shot
- an S3D clip created from them - synced with common TC. (TC sync works)
- a sequence with part of that S3D clip edited in it
If I output this sequence into left/right EDLs, the start TC isn't the right one for on of the eyes - and it's not the same, even if that of the S3D clip are synced to have same TC.
I'll keep the thread posted if I find a solution, but I've tried almost everything...
Best
David
David Steiner
on Mar 20, 2012 at 12:52:10 am
here are the EDLs:
TITLE: SMALLS3DSEQUENCE_L
FCM: NON-DROP FRAME
001 LE__0037 V C 19:32:18:02 19:33:17:03 01:00:00:00 01:00:59:01
* SOURCE FILE: LE__0037_01
TITLE: SMALLS3DSEQUENCE_R
FCM: NON-DROP FRAME
001 RE--0038 V C 19:32:17:20 19:33:16:21 01:00:00:00 01:00:59:01
* SOURCE FILE: RE--0038_01
Michael Phillips
on Mar 20, 2012 at 11:08:16 am
Thanks for sending bin. I will get some time today to take a peek and see what's going on.
Michael
Michael Phillips
