Can only edit in audio on one track
sandy shapiro
on Mar 15, 2012 at 10:46:23 pm
hi,
i have 9 tracks of audio. have a music clip in the source window - only has one track - trying to edit that to track 8 and it only lets me edit into track 9.
any help is appreciated.
thanks,
sandy
sandy shapiro
Re: Can only edit in audio on one track
on Mar 16, 2012 at 2:49:58 am
can anyone please tell me why i cant cut in audio to track 1-8?
Brendan Maghran
on Mar 16, 2012 at 3:11:18 am
Have you checked to make sure the correct tracks are patched and unlocked? Or that your not in record mode? Is it a stereo or mono track?
sandy shapiro
on Mar 16, 2012 at 1:09:55 pm
hi,
im patched to the correct track. im in record mode. i believe its a mono track. it will only let me cut into track 9. if i cut into track nine it wont let me manually move the track up either....
any thoughts truly appreciated.
thanks!
sandy
John Pale
on Mar 16, 2012 at 3:23:02 am
Sounds like you are trying to edit a stereo clip into mono tracks.
Stereo clips can appear as a single track.
To edit the way I think you wish to, you'll have to modify the clip to split it into L/R individual tracks.
Look in Media Composer Help to learn how Stereo tracks work.
Pat Horridge
on Mar 16, 2012 at 8:16:58 am
Or make sure you create a stereo destination track in the timeline to edit to.
Stereo tracks show as having two small speaker icons. Mono only have one.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
sandy shapiro
on Mar 16, 2012 at 1:14:51 pm
got it. i might delete track 8 and recreate it in stereo.
sandy shapiro
on Mar 16, 2012 at 1:12:34 pm
ah. that might be the answer because the new track i added (track 9) was probably stereo so it cut in perfectly? then the other tracks were mono. maybe ill just delete those tracks and make them stereo as thats where my music will live.
how do i convert the clip? too bad just doesnt do this when i cut it in...im sure theres a reason behind it thought
thanks
Pat Horridge
on Mar 16, 2012 at 1:17:16 pm
You can convert a source clip by using the modify command and then multitrack audio.
You can create timeline tracks as mono, stereo, and surround (V6) and you can split a timeline track from stereo or surround to mono. But you can't convert mono timeline tracks into stereo or surround.
The main reason why is backwards compatability with earlier versions of Media Composer. Don't forget unlike most NLEs Avid has a strong reputation and history of backwards and forwards compatability and many rely on that.
Pat Horridge
VET
brian waz
on Mar 8, 2013 at 11:20:52 pm
but is there a click and keystroke to mid pan a mono audio track to centre? I know we could do it in MC 5.5, Cntl or Alt click and it put is at centre. Is the only way to highlight the clip and select clip and center?
thanks
Brian
