Audio waveform not showing
Cammie Noel
on Mar 15, 2012 at 5:29:14 pm
Again new to Avid MC. Want audio waveform to be visible. Went to fast menu and selected it but it is still not showing up.: /
Thanks again.
Michael Hancock
Re: Audio waveform not showing
on Mar 15, 2012 at 5:41:26 pm
Go to your Timeline settings, click on the Display tab, and make sure "Show Marked Waveforms" is unchecked.
Also, on your timeline, click the arrow to the right of the top left timecode display. It will expand little boxes out on the record side track panels. Check the waveform marking there (first little box). See if that helps.
Michael Hancock
Editor
Neil Goodman
on Mar 15, 2012 at 6:01:06 pm
if your talking about in the source monitor, then you need to press toggle source/record button.
Theres a ton of free tutorials that will get you up to speed in MC..i suggest checking them out or at least reading the documentation that comes with Avid.
Neil Goodman: Editor of New Media Production - NBC/Universal
Cammie Noel
on Mar 15, 2012 at 6:28:31 pm
I have done the tutorial before a few times that came with the software, and have also a pdf editing guide. I did what it said, and still have not been able to see the waveform. I will try the advise here Thanks .
Cammie Noel
on Mar 15, 2012 at 6:29:44 pm
Unchecking "show marked waveforms " worked! . Many Thanks!!
Pat Horridge
on Mar 16, 2012 at 8:15:04 am
I prefer to have the setting on and expand the timeline control panel so I can select which tracks show waveforms.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
