Advice new edit system
Brett Allen
on Mar 7, 2012 at 9:38:09 pm
Hi All.
I'm new here and a post rookie. Just wanted to ask for some advice. We have a canon 7d and will be shooting different projects and I wanted to setup my own editing system here at the house. I already have the Avid software.
Can anyone recommend a fairly cheap laptop and storage options with decent speed.
Also, I heard that if you use an external sound device, there's been trouble syncing to the canon footage. Is this true?
Thank you for any help.
Best,
Brett
Michael Jordan
Re: Advice new edit system
on Mar 10, 2012 at 2:48:33 am
Well, I can find you a $10,000.00 storage solution that would work great. ;) Do you have a general idea of how much you're willing to spend?
At the very basic level, you should certainly find a laptop with a 7200 RPM hard drive. Even better would be a 7200 RPM external drive of some sort. If you're doing this as a hobby, that will probably do you fine.
I haven't encountered this (I don't work with DSLR stuff that often), but I could see it as a possibility if you're working directly with the H.264 files off the camera via AMA. In your situation, if you're using a laptop, I would definitely recommend transcoding all the footage to DNxHD upon import for much better performance and to avoid any syncing problem.
Brett Allen
on Mar 10, 2012 at 10:46:49 am
Hi MJ. I never thought you would go into post production after retiring from the Bulls. Surprise.
I've been more of a producer/line producer/writer and haven't been too involved in the tech. side, at least not in detail, more in the general sense. Recently, we bought a 7d to do short projects...maybe documentaries and so forth and to practice editing and directing. So, at this point, I would call it a hobby or just above a hobby and want to spend the minimum price. Later, we'll see how it goes and may upgrade.
Thanks for the advice...appreciate it.
