MXO2 mini and h.264 encode?
Matt Devino
on Mar 7, 2012 at 7:57:44 pm
I did a little bit of searching and didn't find anything on the topic, but I'm just curious if the MXO2 mini only speeds up the output of H.264 from Avid or if it helps on the import side of things as well? It'd be nice to encode DSLR files to DNxHD faster. Thanks for the help.
Matt Devino
http://www.mattdevino.com
Shane Ross
Re: MXO2 mini and h.264 encode?
on Mar 7, 2012 at 9:06:43 pm
The MXO2 Mini with MAX (it's the MAX that does the H.264 encode) only speeds up exporting to H.264. It doesn't speed up encoding to any other codec, including DNxHD.
Shane
Little Frog Post
