Avid MC 6.01 Crashes when scrubbing through Audio. Any Ideas?
Anil Griffin
on Mar 5, 2012 at 10:15:40 am
Hi All
when i attempt to scrub through imported Audio in my Avid project i get the spinning wheel of deat then it crashes.
I can play the Audio files in Avid, i can also play camera Audio and scrub through camera audio files in Avid,
But when i try to scrub through the imported Audio Avid crashes. It crashes soon as i press caps lock and press play.
The system freezes up, with spinning wheel of death.
Eventually i get the following Error:
Exception:Aplayer::NotifyStopStatusCallbacks returned AME_NOTIFYSTATUS_RESULT_FAIL
Then after i press ok i get the good old "Bus sgmentation thread" Error
Have tried various Audio Import settings Have the same problem.
Origional File Format: .WAV Linear PCM, 24 bit little-endian signed integer, 2 channels, 96000 Hz
Anybody have any ideas why this could be happening?
Thank You
Anil
Machine specs: Macbook Pro 17inch early 2011, 2.3 Ghz intel Cre i7, 8 GB 133 MHZ DDR3
Mac OS X 10.7.3
2 x Thunderbolt Display
1 x 8TB Promise Pegasus
Matrox M02 Mini
Avid MC 6.01
John Pale
Re: Avid MC 6.01 Crashes when scrubbing through Audio. Any Ideas?
on Mar 5, 2012 at 8:26:18 pm
It's a bug with Blackmagic and Matrox. If there is no associated video, you can't scrub.
I've tried various workarounds, such as making a multichannel group clip with some random video to get around it. Very annoying, to say the least.
John Pale
on Mar 5, 2012 at 8:41:41 pm
The previous post should say "multicam group clip" not multichannel. Damn auto correct.
Anil Griffin
on Mar 6, 2012 at 12:08:12 am
Hi John
Thanks for your reply, Glad its not just me with this problem.
It does seem to be a bug between Avid and Matrox, I've uninstalled the Matrox driver then the scrubbing works, I reinstall the Matrox driver then it crashes Avid.
Quite annoying, I posted the problem in the Matrox forums too, and Matrox support are looking into it, hopefully we can find some resolve.
Thanks again
Anil
John Pale
on Mar 6, 2012 at 12:45:04 am
Yes. The bug affects Matrox and Blackmagic hardware, but apparently not AJA.
Contact Matrox and Avid. I'm sure they know, as it's been discussed on the official Avid forum, but it won't hurt to keep piling on..its a real annoying bug.
Jeffrey Packard
on Mar 5, 2013 at 8:39:45 pm
had this happen to me today. i do not have a Matrox box nor anything from Blackmagic.
Avid 6.0.1
OSX 10.8.2
Mac Mini3,1
4gb RAM
