Low rez transcoded AMA clip offline - can I batch it?
Daniel Raybin
on Mar 2, 2012 at 6:06:48 pm
Hi everyone,
Stumped on this one.
I've got 28:1 transcoded XDCam-EX footage cut into various sequences. 1 clip (low rez) has gone offline. It looks like the actual MXF media is gone. If this was tape I would just batch capture over the original clip and everything would come back online in all the sequences. How can I accomplish with AMA?
If I relink the sequence and transcode off of that, it makes another .new (.new.02). I need it to directly replace the original .new (.new.01) so the clip comes back in every sequence.
Any thoughts would be appreciated.
Andrew McKee
Re: Low rez transcoded AMA clip offline - can I batch it?
on Mar 3, 2012 at 11:08:12 am
Find the original AMA Master Clip.
Transcode it to whatever res you want.
Now find the offline transcoded master clips -.new(new.01) and relink it, pointing at the drive that media is on. If the media created in step two matches the source file and timedode then it will relink and any sequences referencing it will update.
Andrew McKee
Editor/Colourist
Avid Certified Instructor - MC5.5
Apple Certified Trainer - FCPX
Pixelwizard.net
Daniel Raybin
on Mar 6, 2012 at 7:14:46 pm
That worked splendidly. Thanks!
