How to convert AVin video format
Daniel Waldron
on Feb 28, 2012 at 4:51:14 pm
I was given a QuickTime video file in the AVin format and was told it was some sort of Avid codec. It doesn't play in QuickTime or VLC and won't open in Final Cut or Premiere. I don't have an Avid system and need to be able to convert it so I can edit it in either Final Cut or Premiere. Google has very little on this particular format, so I was hoping someone here might have some insight.
Thoughts?
Daniel Frome
Re: How to convert AVin video format
on Feb 28, 2012 at 8:55:49 pm
Have you tried installing the free avid codecs pack?
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=392959 (download link at the bottom)
Daniel Waldron
on Feb 28, 2012 at 9:08:58 pm
Yes I did. No luck.
I may have to contact someone I know who has Avid, but I was hoping to do it in-house.
Ed Cilley
on Feb 28, 2012 at 9:38:35 pm
Never heard of AVin. Are you sure someone didn't change the extension? Is it an AVI file?
If you downloaded and installed the Avid codecs, contacting someone with an Avid system isn't going to get you any further.
_________________________________________________
Anything worth doing at all, is worth doing well.
- Philip Dormer Stanhope, Earl of Chesterfield
Daniel Waldron
on Feb 28, 2012 at 10:11:22 pm
The file extension is .MOV. I'm assuming it is the codec that is AVin.
When I open the file in the QuickTime player, the audio will play and the inspector says the format is "AVin," as does the "Get info" button in the Finder.
Ed Cilley
on Feb 28, 2012 at 10:24:39 pm
My bad. That's an Avid AVC-Intra codec. I found this link to a set of Avid codecs that may help. http://codecs.org.ua/codecs_en.html - Search for "avin" since there is a lot on that page.
Hope that helps.
Colin Edelman
on May 25, 2012 at 3:46:08 pm
This solution did not work for me. Did you ever find a workaround Ed? Or anyone else?
Colin Edelman
Chris Healy
on Feb 25, 2014 at 11:32:12 am
HI Daniel
Wondering if you had any luck with getting those AVin Quicktime files to open. I can get the files to open on a PC but not on my Mac (even after downloading avids codecs from their website).
Any advice appreciated!
Cheers
Chris
Daniel Waldron
on Feb 25, 2014 at 12:56:29 pm
Never figured it out unfortunately. It was archive footage, so I was able to move on without it. Good luck. Let us know if you figure anything out.
Chris Healy
on May 8, 2014 at 11:19:49 pm
Figured it out.
Download the 30 day free trial for Avid media composer, within the download is a codec pack that works just fine. You can open these files in any program once you've downloaded media composer, I imagine the codec will work after the 30 day trial elapses too.
