Finder indexing
Scott Davis
Finder indexing
on Feb 23, 2012 at 3:30:03 pm
My finder seems to be stuck at half way on the indexing. Is there a way to "force" it to index?
Scott Davis
View Scott Davis's profile on LinkedIn
Hector berrebi
Re: Finder indexing
on Feb 23, 2012 at 5:31:26 pm
sometimes it gets stuck on a bad file in the mediafiles folder.
you can peek in for obvious suspects (syntax stuff usually)and try to put them on the side and re-scan.
or use the method of halves, scanning a half of your media files each time until you find the problem
Hector Berrebi
prePost Consulting
Scott Davis
Re: Finder indexing
on Feb 24, 2012 at 2:56:52 am
Thanks Hector, I was afraid I would have to do that and thought there might be an easy way.
Scott Davis
