Avid liquid pro 7 time code output
David Beck
on Feb 22, 2012 at 11:29:49 pm
I need to output a clip with timecode burned in. How or can I do this in liquid pro 7?
Graeme Hodges
Re: Avid liquid pro 7 time code output
on Mar 25, 2012 at 10:39:48 am
Have been using liquid for years, not aware of any plug ins. I took the time to build a sequence. Using Deko I made 0-24 frames, then fused it, then I made minutes and seconds by creating over 2 tracks (tens & singles) 0-9 at 1 second each, and 10 seconds on the second for the tens, copied etc and then fused that, doing the same for minutes at appropriate durations. Then using the fuses repeated appropriately and 2d move to crop as appropriate, the a final Deko with the colons and hour, then fused that (keeping render down) now you have a clip that you can crop and place on your vision. It sounds convoluted, but is very quick to make and easy to use.
On the up side MC6 does it for you...
David Beck
on Apr 23, 2012 at 6:18:19 pm
What is MC6. I need to put time code or control track on some tapes and I need the easiest way to do this
David
