Consolidating
Lloyd Paul Rivers
Consolidating
on Feb 20, 2012 at 5:29:28 pm
I need to consolidate to take the project into uni. It went through the process then said multiple clips weren't consolidated. please transcode to a native codec and try again.
is there any way to see exactly which clips are needed to transcode? it didnt give me any hints as to which they were
Many Thanks
Lloyd Rivers
Shane Ross
Re: Consolidating
on Feb 20, 2012 at 5:55:06 pm
What version of Avid MC are you using? Some versions can't consolidate some footage that is accessed via AMA.
And footage that is accessed via AMA is either highlighted in YELLOW in the bin, or otherwise colored.
Shane
Little Frog Post
Lloyd Paul Rivers
Re: Consolidating
on Feb 20, 2012 at 6:01:07 pm
Hi thanks for the quick reply. Im using Version 6. All bought and paid for. I have a first year project due in 2morro and i cant get it out and onto a dvd.
I have attached a screen shot. None of the clips in the bins are different in colour
Many Thanks
Lloyd Rivers
John Pale
Re: Consolidating
on Feb 20, 2012 at 6:21:38 pm
The shining clip, the citizen Kane clips and the one at the bottom of Goodfellas are AMA clips.
Lloyd Paul Rivers
Re: Consolidating
on Feb 20, 2012 at 6:24:06 pm
so whats the solution?
Many Thanks
Lloyd Rivers
Lloyd Paul Rivers
Re: Consolidating
on Feb 20, 2012 at 6:24:36 pm
so thats all of them, how come they are not in yellow
Many Thanks
Lloyd Rivers
John Pale
Re: Consolidating
on Feb 20, 2012 at 6:25:34 pm
If the subclips are all from the clips I mentioned, all your footage needs to be transcoded.
AMA has a new icon, which I guess is meant to indicate linked. Regular master clip icons look different.
John Pale
Re: Consolidating
on Feb 20, 2012 at 6:27:01 pm
AMA no longer uses yellow (which I am happy about,as in my color scheme, it made the info hard to read.
Lloyd Paul Rivers
Re: Consolidating
on Feb 20, 2012 at 6:29:28 pm
Is it easier to duplicate the sequence then transcode that sequence or go back to the original media folders where i linked from and do it there?
Many Thanks
Lloyd Rivers
John Pale
Re: Consolidating
on Feb 20, 2012 at 6:31:40 pm
Transcoding automatically duplicates the sequence.
Lloyd Paul Rivers
Re: Consolidating
on Feb 20, 2012 at 6:34:24 pm
thanks John
Many Thanks
Lloyd Rivers
