Function similar to clip enable
Joe Klaw
on Feb 16, 2012 at 4:29:06 pm
Is there a function in Media Composer similar to Final Cut Pros' clip enable.
Shane Ross
Re: Function similar to clip enable
on Feb 16, 2012 at 5:39:28 pm
Nope. But you can monitor below layers...choose what layer to view. The option in on the timeline on the far left. Just to the right of the V1, V2. The cool thing is that you can choose to not monitor a layer, and it DOESN'T undo your renders, like FCP does.
Shane
Little Frog Post
Andrew McKee
on Feb 16, 2012 at 9:55:32 pm
You could create an effect template that has 0 opacity and just apply that to a clip to disable it. Any effect in the Blend catagory should work fine.
Andrew McKee
Editor/Colourist
Avid Certified Instructor - MC5.5
Apple Certified Trainer - FCPX
Pixelwizard.net
