MC6 Sluggish/Lag while Trimming
Matt Osborne
on Feb 16, 2012 at 5:17:40 am
I posted this on the AVID community forum but didn't get any responses...
I'm having an issue with MC6 being quite sluggish while in trim mode and moving shots in both segment modes.
In trim mode - adjusting frames using the keyboard commands for trim 1 frame or 10 frames.
Also in either segment mode sliding shots using the same key commands.
Basically each command takes 1/2 a second or so to respond. For example if i hit the , 5 times to trim 5 frames it would take 2-4 seconds for this to happen.
This is not a problem using it in software only mode, works perfectly there, only a problem when outputting - have tried a BM Decklink Extreme and an AJA Kona 3.
Have tried this on 3 separate computers, 2 with the same specs, 1 vastly different. See below...
Computer #1+2
Mac Pro, 2 x 3 GHz Quad-Core Intel Xeon, 8GB Ram, ATI Radeon X1900 XT, 10.7.2
Computer #3
Mac Pro, 2 x 2.93GHz 6-Core Intel Xeon, 24GB Ram, NVIDIA GeForce GTX 285, 10.7.2
I know a couple of people have mentioned having lag/sluggishness isues with the Matrox MXO mini but there hasn't been any mention of issues with BM or Kona cards. Is no-one having this issue or do they just put up with the delay?
Shane Ross
Re: MC6 Sluggish/Lag while Trimming
on Feb 16, 2012 at 8:00:02 am
what type of footage are you working with? Imported how?
Shane
Little Frog Post
Chris Conlee
on Feb 16, 2012 at 4:38:52 pm
My sense is that MC 6.x broke something with their "open architecture." Given that there are now multiple reports of sluggish behavior using products from different vendors, I think the problem lies with Avid. MC 5.x was smooth as butter with the Matrox MXO2 Mini. It's now almost unusable. The new drivers from Matrox (for PC only, so far) supposedly improve the situation, but not much.
Hopefully Avid will figure this out sooner than later, because I can't afford to buy a Nitris box.
Chris
Matt Osborne
on Feb 16, 2012 at 10:20:32 pm
Just to clarify, same issue with 6.0 and 6.0.1.
Matt Osborne
on Feb 16, 2012 at 10:18:56 pm
Hi Shane, have tried HD and SD, prores via AMA and imported (to both ProRes MXF and DNxHD), all PAL 25p and 50i.
Footage is Red One, Red Epic, Alexa, 5D and even SD footage from Digi Beta.
All has the same issues.
Steve Eisen
on Feb 18, 2012 at 5:50:27 am
[Matt Osborne] "Footage is Red One, Red Epic, Alexa, 5D and even SD footage from Digi Beta"
What hard drive (RAID) are you working from? You need a fast RAID setup.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Matt Osborne
on Feb 20, 2012 at 10:01:10 pm
Hi Steve, 56TB Promise Raid. Runs at 900MB/s so is definitely not the issue. Playback is perfect, it is literally just the issues i mentioned in my original post.
Surely there are others using third party i/o out there, BM or Kona? A simple yes i have these issues or no i don't would be great to hear.
Thanks.
alec gitelman
on Feb 27, 2012 at 8:12:41 pm
Matt,
were you able to find an answer to your problem?
i'm running a test version of MC 6 on a Mac Pro and i'm experiencing similar sluggishness with all kinds of commands - play, playhead position, etc., while i have no issues with playback.
Alec.
Matt Osborne
on Feb 27, 2012 at 9:47:13 pm
Nope, unfortunately not. I've been told second hand that it's a known issue to AVID and will be fixed in 6.0.2 but i'm still astonished that no one else is talking about this.
alec gitelman
on Feb 27, 2012 at 10:10:38 pm
wow, that's frustrating..
alec gitelman
on Feb 27, 2012 at 10:10:13 pm
Matt Osborne
on Feb 27, 2012 at 10:13:32 pm
What are your mac pro specs? Are you using Kona or BM?
alec gitelman
on Feb 27, 2012 at 11:33:14 pm
i am not using any additional hardware.
2x2.8Ghz Quad-Core Xeon
12 GB RAM
ATI Radeon HD 2600 XT 256 MB
Matt Osborne
on Feb 27, 2012 at 11:43:46 pm
So you're having issues just using the software version, no video out? That's interesting, if i turn off video out everything works perfectly.
alec gitelman
on Feb 28, 2012 at 8:09:48 pm
i may have found the reason.
i'm using AMA with .mov files that use XDCam EX compression. when i opened an exercise project that uses MXF files the stickiness disappeared.
but it still doesn't make sense, why advertise AMA capabilities if they don't work well?
Joseph Mastantuono
on Mar 23, 2012 at 10:57:55 pm
New to Avid (well not really, but haven't used it in about 6 years), but I'm getting the EXACT same issue. I'm doing a project with the trial to see if I'm going to go with Avid or Premiere as my main editor. Makes working such a drag.
Joseph Mastantuono
http://www.goodpost.net
Color Grading & Post Production Consulting
Shane Ross
on Mar 23, 2012 at 11:01:45 pm
WOrking with Avid media, or media accessed via AMA, that you haven't transcoded yet?
Shane
Little Frog Post
Charles-Etienne Viau
on Apr 13, 2014 at 7:15:10 pm
Hi guys,
Its been 2 years after this last post.
Now its MediaComposer 7.0.3 with AJA IO XT and having the same exact issue the you are talking about (Sluggish/Lag) in timeline and Trim mode.
Anyone got to resolve this one ?
When hardware is ON, its very slow on scrub, when Hardware is OFF the scrub is perfect (real time) (HW / SW) ON / OFF
2 x Avid MediaComposer 7.0.3 with AJA IO XT or KONA 3 (both systems same issue)
10 TB Pegasus Promise RAID
AMA XDCAM EX or MXF DNx145 footage got same issue (1080i59)
OS 10.8.5 (i7 3.4GHz, 16GB 1600MHz DDR3)
AJ Open IO 10.4.9, AJA Driver 10.5.1
