Cannot import mixed resolution Quicktime movies
Pat Baril
on Feb 9, 2012 at 7:56:23 pm
Hello,
I have a consolidated sequence in DNXHD36. When I want to batch import the clips in Hires ( actually original clips are DSLR, converted to DNXHD36 for offline and Prores422 for online, by compressor ), I locate the Prores422 files, set the import setting to Prores MXF, but when I hit import, nothing is done and the console is full of : Exception: Cannot quick import a mixed resolution QuickTime movie.
I have tried what they say here:
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=278487
But no succes. I even recompressed the original DSLR file to DNXHD120 in compressor ans retry batch importing in DNXHD120 but same error.
I am running MC6.0.1....
Any idea??
PAT
Maria Maysova
Re: Cannot import mixed resolution Quicktime movies
on Oct 30, 2012 at 1:41:12 am
Hi, Pat!
Does anybody helped you with your problem?
Because I'm stucked with the same thing and can't figure out how to fix it.
So, if anybody gave you advice that works, please share it with me)
Thanks a lot!
Maria
Roman Stricker
on Nov 8, 2012 at 11:07:50 pm
Hi Pat,
I got the same issue here and can't find a solution. How did you solve your problem back in February?
Cheers,
Roman
