Moving Avid Project to Final Cut Pro?
Khoren Mirzakhanian
on Feb 8, 2012 at 11:55:56 pm
Hey everyone,
Ive hit a roadblock on trying to understand what is the best way of moving an Avid Project to Final Cut Pro.
Not just an avid sequence, but also all media that was digitized or imported.
Any advice? thank you
John Pale
Re: Moving Avid Project to Final Cut Pro?
on Feb 9, 2012 at 12:57:07 am
You can move sequences with or without media using this:
http://automaticduck.com/products/pefcp/
You can't really move your project and bin structure.
Shane Ross
on Feb 9, 2012 at 7:05:47 am
Yeah, and since the media is all MXF, not Quicktime, FCP won't be able to even see it. The Duck converts the media in the sequence to QT...rather makes QT reference files that point to the MXF files. But it won't convert ALL of the media, nor bin structure...as John says.
There really is no way to transfer full projects from Avid to FCP...or FCP to Avid.
Shane
Little Frog Post
Ray Chung
on Feb 9, 2012 at 9:30:16 am
What I did with Automatic Duck was actually make sequences in AVID where all the full raw clips in scene bins were laid out back-to-back, then export those sequences individually. Later, I'd open them in FCP, then drag/paste all the clips in those open sequences into their own bin. A pain in the ass, but I had to do it to have full access to raw material for a re-edit on a project that started in AVID.
Jeff Coleman
on May 18, 2012 at 3:47:44 pm
You exported the raw clip sequences using Automatic Duck from AVID.
You opened those sequences in FCP.
But how did you get playable media into FCP?
