Adding Filler between 2 clips?
Greg Jones
on Jan 30, 2012 at 4:19:02 pm
This is probably something easy, but I can't seem to figure out how to add filler in between two clips in Media Composer 6. I can add filler to the beginning of a sequence, but can't seem to find a command to pull filler up in the source monitor to insert it into my timeline.
Greg Jones
D7,Inc.
Orlando,FL.
http://www.d7-inc.com
Peter Groom
Re: Adding Filler between 2 clips?
on Jan 30, 2012 at 4:34:31 pm
Is "Load Filler" not in the drop down menu top left of the source monitor
Peter
Post Production Dubbing Mixer
Greg Jones
on Jan 30, 2012 at 4:52:51 pm
That's where it is. Thank you. I didn't look there.
steve knattress
on Jan 31, 2012 at 9:24:12 am
Just a point that filler cannot be added onto the end of a sequence.
(eg extend sequence to add an audio punch in or to give a gap before next timeline clip.)
I just make a black slug (disable "V" to loose transparency) with the title tool and use that.
Steve
Justin Gray
on Jan 31, 2012 at 10:00:24 pm
The title tool trick the Steve mentioned works great. Also, one thing I find incredible handy, is to keep a bin stored on your desktop and cloud that serves as a utility bin. Inside that utility bin I have black slugs, bars/tone sequences, slates and any other "quick grab" stuff I might need. From within any project I can open that utility bin and then I have everything I need.
Thanks Fellow Bovines,
Justin Gray
Senior Editor/Motion Graphics Artist
Encore Multimedia
web.me.com/grayplanet
michel armstrong
on Sep 20, 2012 at 10:36:21 am
Does Filler can disinfect ?
Rosie Walunas
on Nov 12, 2012 at 10:09:55 pm
I'm having an issue where the "Load Filler" option is no longer present. How do I fix this?
Thank you.
