Arghhhh!!!!
Scott Davis
Arghhhh!!!!
on Jan 25, 2012 at 1:07:06 am
So I'm happily script synching away on a 2 hour long interview. 28 or 30 clips are assigned to the transcript and I get to the last two clips of interview and there is no transcript for it???? Somehow it got emitted in the creation of the transcript. Is there a way to add the last bits of transcript, re-import the correct transcript and move all my work of assigning the clips to it? Or do I have to start all over again?
Scott Davis
View Scott Davis's profile on LinkedIn
Michael Phillips
Re: Arghhhh!!!!
on Jan 25, 2012 at 2:20:09 am
Just copy/paste the missing section into the already synced script.
Michael
Michael Phillips
Scott Davis
Re: Arghhhh!!!!
on Jan 25, 2012 at 2:28:47 am
Wait a second. Do you mean I can change the script once it is in Avid and within Avid?
Scott Davis
Michael Phillips
Re: Arghhhh!!!!
on Jan 25, 2012 at 2:38:58 am
You can't edit text directly, but you can extract, copy, and paste from external document where changes can be made. You can insert a block of text and everything moves down and remain in sync. Then you can just choose to sync between existing marks (in settings if I remember correctly).
Michael
Michael Phillips
