Shot video at too fast shutter speed-how to smooth out choppiness
Eva Miller
on Jan 24, 2012 at 4:14:06 pm
I shot some footage on the red at a shutter speed of 125 and now the pans are choppy. Is there a way in editing to smooth out the movement? Thanks!
Brendan Maghran
Re: Shot video at too fast shutter speed-how to smooth out choppiness
on Jan 27, 2012 at 12:39:55 am
Well, for the short answer, no there is not. What frame rate did you shoot 1/125 at?
Ray Chung
on Jan 28, 2012 at 9:01:59 pm
I don't thing there is without actually adding some motion blur to each frame via an effects program or the like...don't think there's a plugin/effect for tat in Avid but I may be wrong. Maybe you could try some things with the 'Time Warp' effect in Adobe After Effects...which can be used to create 'virtual slomos' and basically add/warp the missing in-between frames of movement. Maybe a slo-mo back to regular or something. But no, if the shutter speed is such that it doesn't capture as much motion blur @ normal speed and hence has that 'choppy' look (like some of the beginning of Saving Private Ryan)...then it's nowhere to be extracted back from. It'll have to somehow be manufactured.
