Adding keyframes v6
Ron Dylewski
Adding keyframes v6
on Jan 23, 2012 at 7:31:20 pm
I can no longer simply push the keyframe button to set keyframes on a graphic clip. The only way I seem to be able to add new keyframes is to expand the advanced keyframe panel and add one using the dialogue there. Is this correct, a bug, or something I'm doing wrong?
Thanks.
Ron
Photos, news, memories and musings on the great American Roadside experience
http://www.theamericanroadside.com
Snarky daily political and pop culture satire!
http://mytabloids.wordpress.com
Hector berrebi
Re: Adding keyframes v6
on Jan 23, 2012 at 9:35:34 pm
maybe you have "add to active parameter" in the keyframe menu and no parameter is active, or something of the sort.
if you want to work old school... check "add to all parameters", it will work just like it used to
hector
Hector Berrebi
prePost Consulting
