Step by step should you get the dreaded "error has occurred restart your comp" promp
David Powell
on Jan 6, 2012 at 6:36:40 am
First open all your bins. This worked the first time. I don't know why but it did. If it doesn't, try go to your avid media folder and delete the database files start up MC and it will rebuild. If that doesn't work, go to the the timeline hamburger menu, click "clip color" and select "color offline clips". Find the clips that are offline, reimport them and recut them into your clips. Hopefully you know what the cut was supposed to look like.
This will solve the problem. For some reason "relink" never freakin works when a clip goes offline for me.
Hope this saves someone a few hours.
Scott Cumbo
Re: Step by step should you get the dreaded "error has occurred restart your comp" promp
on Jan 6, 2012 at 1:43:34 pm
just batch import stuff if it goes offline, though things going offline is rare in my experiance
Scott Cumbo
Editor
Broadway Video, NYC
David Powell
on Jan 6, 2012 at 6:25:01 pm
I believe the media had become corrupted.
