Can MC 5.5 open a media composer 6 project?
Andy Field
on Dec 17, 2011 at 2:55:03 pm
Need to deliver finished timelines to a post-house that's still on 5.5 -- is it possible to to a SAVE AS 5.5 out of version 6 - or can 5.5 read a 6 project? If not are there other options like XML out? Thanks
Michael Hancock
Re: Can MC 5.5 open a media composer 6 project?
on Dec 17, 2011 at 3:07:04 pm
The project should transfer fine. I don't believe the Pan and Zoom plugin is backwards compatible though so if you used it the moves will have to be recreated.
Michael Hancock
Editor
Andy Field
on Dec 17, 2011 at 3:53:53 pm
Great - has anyone actually tried this backward compatibility? I'm downloading a trial of 6 and will report if it actually works - Thanks
Andy Field
FieldVision Productions
N. Bethesda, Maryland 20852
John Pale
on Dec 17, 2011 at 10:18:44 pm
Works fine. Done it several times already
Philippe Ralet
on Dec 27, 2011 at 2:52:13 pm
Hi have upgraded in past two weeks, have sent bins with sequences , including alpha channels, mattes keys, but no major effects. All is good, no problem whatsoever .... he says cautiously
Let's get this done and go outside and play !!!
Mike Most
on Dec 18, 2011 at 6:11:33 pm
Repeat 3 times:
I am not on Final Cut anymore.
Then rejoice that you're using software produced by a company that actually understands the editing business and doesn't ignore things like backwards compatibility.
John Pale
on Dec 19, 2011 at 1:45:52 pm
"Then rejoice that you're using software produced by a company that actually understands the editing business and doesn't ignore things like backwards compatibility."
Mostly true...however Avid made a change to the DNX codec several years ago (around MC 4?)to meet SMPTE spec that causes some tricky issues with backwards compatibility.
Generally no problem with bins and projects, though. Way better than FCP.
