PC project and mac compatibility question: IMPORTANT!
Caitlin miller
on Dec 15, 2011 at 3:59:18 pm
I inherited a projet that was created on a PC and I'm using a Mac, so the project just wouldn't open. It kept saying it was locked. So I downloaded a trial version of Paragon NTFS and was able to open the project. Since paragon worked, I bought it. This morning I went to open the project and I can't open it anymore. I keep getting this error msg:
Assertion failed:logicalDur > 0
File:/Snapshot/relengsnow2_1280545329/coresw/ame/
Project/Mac/../../src/player/match.c, Line:3533
I pressed continue, then got this message:
"Bus error" in thread "MainThread", at address 0X0
I don't know what to do, I'm panicking a little here. Has anyone ever encountered this before? Is this a Paragon support question or this an Avid thing?
John Pale
Re: PC project and mac compatibility question: IMPORTANT!
on Dec 15, 2011 at 4:09:00 pm
Are you saying your Media is on an NTFS volume?
There should be no issues in compatibility. I move Avid projects between Mac and PC all the time.
Andrew McKee
on Dec 15, 2011 at 4:10:28 pm
Even though Paragon etc do allow you to access NTFS drives I would never put anything on there that is constantly being written to and changed like a project folder. Have you tried simply moving the project folder onto a Mac formatted drive and opening it from there?
Andrew McKee
Editor/Colourist
Avid Certified Instructor - MC5.5
Apple Certified Trainer - FCP7
Pixelwizard.net
Caitlin miller
on Dec 15, 2011 at 4:18:43 pm
Yes I have tried to move it all to a mac formatted drive, but the content on the timeline in that copied project doesn't show up, it's just offline. What I wanted to do was collect all the media and copy it onto a mac formatted drive, but I can't do that if I can't even open the project!
Ed Cilley
on Dec 15, 2011 at 4:42:22 pm
You may need to copy everything first, so you can open the project on the Mac. Yes, you will have lots of extra footage, but this may be what you have to do.
1- Make sure your media lives on the Mac drive in the same folder structure as the NTFS drive. "Avid MediaFiles" should be at the root level.
2- Copy the project off the NTFS drive and store it on your internal drive (or Mac Formatted drive).
3- Open the project.
4- Consolidate as desired.
_________________________________________________
Anything worth doing at all, is worth doing well.
- Philip Dormer Stanhope, Earl of Chesterfield
Matthew Mullen
on Dec 15, 2011 at 5:51:12 pm
Could be the project settings. In the projects folder you'll see a files named .avs, try removing this file (move to the desktop for example) and launching the project.
