Incompatible Edit Rates
Erik Lutsch
on Nov 29, 2011 at 10:45:49 pm
I'm attempting to multigroup 2 cameras in a 23.98 project and I'm receiving the error "incompatible edit rates." Has anyone encountered this issue before and have a solution?
Shane Ross
Re: Incompatible Edit Rates
on Nov 29, 2011 at 11:28:35 pm
Did both cameras shoot 23.98? Both have the same dimensions?
Shane
Little Frog Post
Erik Lutsch
on Nov 29, 2011 at 11:35:25 pm
Yes, both cameras are shot 23.98 at 1080p and this is a 23.98p 1080p project.
John Pale
on Nov 29, 2011 at 11:52:50 pm
What codec/resolution?
Any BWFs or other audio files involved?
Erik Lutsch
on Nov 30, 2011 at 3:16:39 am
The codec is DNX35 1080p. There is 4 channels of audio for each cam and backup audio. Multi group does work when I only group clips that overlap each other in a sequence.
Job ter Burg
on Nov 30, 2011 at 10:44:47 am
If you splice both cams into to the timeline, ungrouped, does either one of them show the green dot?
Glenn Sakatch
on Dec 1, 2011 at 2:53:52 pm
did your project "format" get changed to 720?
Glenn
Erik Lutsch
on Dec 1, 2011 at 4:15:29 pm
No, it is a brand new project and has been a 23.98 project from the start.
Erik Lutsch
on Dec 1, 2011 at 4:19:30 pm
After I receive the error, I get 40-60 multigroup clips depending on the amount of footage in the sequence. Each multigroup is a section of the sequence. It would be nice to get one multigroup sequence, but it seems like that isn't possible.
Joel Salazar
on Aug 14, 2013 at 6:16:07 pm
how did you resolve this issue?
Erik Lutsch
on Aug 14, 2013 at 7:47:00 pm
Yes, I exported an ALE and reimported it. The metadata might have been corrupted. Reimporting an ALE file fixed it.
