Setting a "poster frame" in frame view.
Scott Davis
on Nov 26, 2011 at 2:41:02 pm
When in frame view for a bin; is there a way to set a poster frame for the clip?
Scott Davis
View Scott Davis's profile on LinkedIn
Michael Phillips
Re: Setting a "poster frame" in frame view.
on Nov 26, 2011 at 2:46:00 pm
Select one or the clips:
1. Single frame advance key moves all frames + 1 frame
2. 8/10 frame advance key moves all frames + 8/10 frames
(reverse is true in both cases)
On a single clip:
1. Load and play in source monitor to desired frame and Mark IN
2. Play directly from bin to desired frame and Mark IN
Then use the "got to mark in" (Q key) and all clips will go to that mark.
Michael
Michael Phillips
