No Timeline in Media Composer 6
Thomas Frank
on Nov 22, 2011 at 10:49:57 am
So, I have downloaded a trial of Media Composer 6 to give it a try since AVID is praisinig it so highly.
First I followed the steps of crating a Project importing media and creating a Sequence.
So where is the timeline and the monitors??
Double clicking any of the clips or sequences seems not work. What is the next step?
Ed Cilley
Re: No Timeline in Media Composer 6
on Nov 22, 2011 at 4:09:17 pm
Are you using two monitors or one?
_________________________________________________
Anything worth doing at all, is worth doing well.
- Philip Dormer Stanhope, Earl of Chesterfield
David Parker
on Nov 22, 2011 at 7:49:30 pm
I got that bug on one of the systems I installed MC6 on. I think it might be the geforce 7300 GT, the other system where it works fine is a Radeon HD 4870. Trashed all the prefs I could find, no better, uninstalled, and reinstalled MC6, no fix. Ended up just mirroring my two displays so I could run the tests I need to run, luckily I don't need to actually edit with it.
Thomas Frank
on Nov 22, 2011 at 9:23:57 pm
Yes it is a Dual Monitor setup.
Also it does have a geforce 7300 GT. :(
Oliver Peters
on Nov 23, 2011 at 1:49:51 am
There's a bug that was missed. With dual-monitor Mac set-ups, put your menu bar on the left monitor (Apple System Preferences/Displays/Arrangement). Avid has promised to fix this in a patch that will likely come soon.
- Oliver
Orlando, FL
http://www.oliverpeters.com
John Pale
on Nov 26, 2011 at 6:46:44 pm
I thought Avid was trying to one-up FCP X...
Apple gets rid of tracks...Avid gets rid of,the whole damn timeline !
Thomas Frank
on Nov 27, 2011 at 2:01:46 am
lo John I like that one. It seems not only does mistakes with there new released software but they sure get hit up with it. ;)
Going to give the trial on a new Mac a try.
Thomas Frank
on Jan 29, 2012 at 10:26:05 am
Forgot they got it up running thanks for the tips.
But what we would like to know how to get the new window layout... the that looks similare to FCP in the dark gray color scheme.
Right now ist the normal MC 5 floating madness window layout.
joe andolina
on Jul 6, 2012 at 6:40:40 am
One little work around for me is temporarily change the bar under preferences to the left monitor as mentioned, and after I get the time line to show, move the bar back to the right monitor and move the timeline to the right monitor, at least the timeline then seems to not disappear. A little inconvenience, but it seems to be okay at the moment.
