Transferring export presets between users.
Scott Davis
on Nov 21, 2011 at 7:35:51 pm
Is there a way to transfer export presets into the settings of another user?
Scott Davis
View Scott Davis's profile on LinkedIn
matthew bradshaw
Re: Transferring export presets between users.
on Nov 21, 2011 at 9:11:19 pm
Same way you transfer any setting. When in the setting window click file, open setting file, navigate to the setting file and then drag the export setting (or any other setting) into your setting window.
Matt.
Scott Thomas
on Nov 22, 2011 at 10:09:39 am
The other way to do it is to open the "site setting" window found in the Special menu. Just drag a setting into that window, change user and drag it back into the settings. It will be added to that user's settings.
