Batch import not working
Mike Halper
on Nov 17, 2011 at 9:39:28 pm
I'm trying to batch import a number of clips that are offlien using MC 6. It goes through the processing of what appears to be transcoding to DNxHD and then gives an error like "0 of 20 clips imported. See console." In concole I get the following for each clip:
Total AVCHD audio execute time is I64d microseconds
Total AVCHD video execute time is I64d microseconds
binImportMpeg - Audio tracks are longer than master mob.
BatchImport::RelinkToMaster - IMPORT_TOO_SHORT
Cannot reduce duration of clip shorter than current duration
theMasterComp=1572 masterMob=1569
Batch import clip 1 of 1 FAILED: 1J take 1 with error:
Batch imported 0 of 1 clips
The folders it points to for the original source files is correct. This was a 5.5.3 project that I've opened in MC 6. Any thoughts?
© 2018 All Rights Reserved
