Exporting from After Effects to Avid MC5 (again!)
jack wormell
on Nov 17, 2011 at 5:07:07 pm
Hi There
I'm doing credits for an Avid Project (DNxHD 185, 25fps, 10bit, 1080x1920p) in After Effects. I've exported it to DNxHD185 for Avid but the credits look a little strobey on playback. I'm trying to keep the settings identical as much as possible. Any extra tips?
Jack
Andrew McKee
Re: Exporting from After Effects to Avid MC5 (again!)
on Nov 17, 2011 at 6:03:43 pm
Is it doing a fast import when you bring it into Avid?
Andrew McKee
Editor/Colourist
Avid Certified Instructor - MC5.5
Apple Certified Trainer - FCP7
Pixelwizard.net
jack wormell
on Nov 18, 2011 at 7:58:18 pm
Hi
Not sure what you mean by 'fast import'?
I'm not using AMA, Avid makes it's own MXF of the files as per usual. Takes about 3mins I think.
Jack
Jeff Greenberg
on Nov 19, 2011 at 2:32:56 am
Stroby:
Usually, this is because the speed of the vertical motion (I'm assuming vertical credits) from AE. You want them going at the specific velocity of 60/120/180/240 etc in NTSC...even in HD.
Fast Import:
After that, when you generate your DNxHD file from AE, as a QuickTime, you should see the words "Fast Import" when you import it into MC. If you've 'done it right' with the render in AE and the Import Settings in MC, then the avid merely unwraps the video from QuickTime and rewraps into MXF.
Best,
Jeff G
Certified Master Trainer | Adobe, Apple, Avid
You should follow me (filmgeek) on twitter. I promise to be nice.
New! FCPX DSLR workflows; What's new in Media Comopser 6; Full Media Composer 6 basics from macProVideo.com
Come see me speak at the Government Video Expo Nov 30 - Dec 1; Seminar link here
My book (with Richard Harrington and Robbie Carman)- An Editor's Guide to Adobe Premiere Pro
Lynda.com - Compressor Essentials 3.5 and 4
Contact me through my Website
jack wormell
on Nov 19, 2011 at 6:09:42 pm
Thanks for the help Jeff, but I'm not sure what you mean about the speed of the credits. '60/120/180/240' are these specific options on AE?
jack
Jeff Greenberg
on Nov 19, 2011 at 8:41:52 pm
Jack,
That's the velocity of the text in AE. Roll open the X position and you should see a numerical pixels per second value.
Best,
JG
