Avid media composer 5.5 xd cam ex 1080i video footage slow motion
siraj uddin
on Nov 13, 2011 at 10:13:05 pm
Hi Everyone,
i am editing some xd cam ex 1080i footage i need to know the slow motion mode for hd 1080i footage.I have tried the default slow motion but it was not good (ie not smooth,juddery or jerky}.Any help welcome.Thanks.
Scott Cole
Re: Avid media composer 5.5 xd cam ex 1080i video footage slow motion
on Nov 13, 2011 at 10:54:32 pm
If you are using Timewarp, I'd suggest you try Blended Interpolated as the render method. I find it the best bang for the buck in terms of quality vs render time. If you need the absolute best quality, try fluid motion, though render times go up dramatically. If not using Timewarp for slo-motion (i.e. fit to fill), promote the effect to timewarp and follow the above.
M. Scott Cole
Senior Post Production Editor
60 MINUTES
CBS News, NYC
sc6@cbsnews.com
mscottc@comcast.net
Job ter Burg
on Nov 13, 2011 at 10:56:55 pm
The default method is Duplicated Field, which discards half of each frame. Both Fields will cause stutters when slowing down interlaced sources. The better options would be Interplolated, Blended Interpolated, or FluidMotion.
