PDW-F1600 Deck Configuration trouble in Avid
Dan McGuire
on Nov 12, 2011 at 1:45:30 am
We're working with a PDW-F1600 XDCam deck, and I'm failing to get any kind of deck control in Avid, running version 5.5.
Any time we attempt to auto configure the deck, Avid simply reads it as "No Deck." We've tried manually configuring it as a Generic deck, but it doesn't change the fact that Avid seems unable to even see it.
Tested to be sure that we have the correct COM port selected, and Avid has no problems configuring our other decks, but for some reason, it simply will not see the PDW-F1600.
Has anyone run into this problem? Is there something we're missing about configuring this specific deck to work with Avid?
Thanks in advance.
Gary Hazen
Re: PDW-F1600 Deck Configuration trouble in Avid
on Nov 12, 2011 at 4:06:31 pm
Overstating the obvious, is the deck in remote?
The control switches on the front of the unit are very small so it's easy to be in local mode instead of remote.
Have you tried a device preset that uses the Sony protocol, such as DVW-500 or BVW-75 ?
