sooo... anyone knows what's the new DNX bitrate?
Hector berrebi
on Nov 4, 2011 at 5:20:37 am
DNXHD 4:4:4 RGB... i couldn't find it anywhere in the release notes or on the Avid website.
maybe i didn't look hard enough, but at a first glance (and second and even third) it seems like its not info Avid deems important to share. i think its strange.
oh how long i've waited for this one DNX 4:4:4... all warm inside.. :)
hector.
Hector Berrebi
prePost Consulting
Job ter Burg
Re: sooo... anyone knows what's the new DNX bitrate?
on Nov 4, 2011 at 7:11:57 am
Ranging from 442Mb/s for 720p23.976 to 1989Mb/s for 1080i59.94.
Hector berrebi
on Nov 4, 2011 at 12:29:43 pm
[Job ter Burg] "Ranging from 442Mb/s for 720p23.976 to 1989Mb/s for 1080i59.94."
hi Job
that sounds very interesting... if i'm calculating right, that's 2:1.
where did you get this info from?
is there white paper for the new DNX?
hector
Hector Berrebi
prePost Consulting
Job ter Burg
on Nov 4, 2011 at 6:26:07 pm
Pretty sure it's uncompressed 4:4:4 RGB.
Hector berrebi
on Nov 4, 2011 at 7:08:47 pm
[Job ter Burg] "Pretty sure it's uncompressed 4:4:4 RGB.
you're right, i was calculating for 60P not i
but if its uncompressed... why is it DNX? and how is it different from what's currently available?
i'm still betting in the area of 2:1
Hector Berrebi
prePost Consulting
Chris Conlee
on Nov 5, 2011 at 12:17:13 am
Yeah, it's gotta be compressed, 'cause the marketing literature says something about maintaining your pristine color in a bandwidth-friendly manner (or words to that effect)...
Chris
Job ter Burg
on Nov 5, 2011 at 9:13:53 am
If you do the maths, it is uncompressed. Period. The data rates I quote are correct.
Job ter Burg
on Nov 5, 2011 at 9:18:26 am
P.S.: They don't label it as DNxHD. It is labeled "1:1".
Hector berrebi
on Nov 5, 2011 at 10:12:41 am
[Job ter Burg] "P.S.: They don't label it as DNxHD. It is labeled "1:1".
then why make a big deal of it and publish as a new feature?
rgb 4:4:4 1:1 has been around for a while
http://www.avid.com/us/products/media-composer?intcmp=AV-HP-S2
Hector Berrebi
prePost Consulting
Job ter Burg
on Nov 5, 2011 at 5:10:58 pm
I think I am mistaken and indeed am confusing the existing 4:4:4 RGB 1:1 10bit resolution with the new one.
Mike Most
on Nov 5, 2011 at 5:16:36 pm
No, if you do the math, it is approximately 2.5:1. Uncompressed HD is approx. 1.2 gigabits per second. The 440Mb rate is essentially identical to HDCam SR, and identical to the SR Master format Sony is offering with the F65.
Job ter Burg
on Nov 5, 2011 at 7:20:20 pm
Ah, so 444 is not just 4:4:4 but also 444 (unlike 175). I get it now. Thanks.
Hector berrebi
on Nov 6, 2011 at 2:57:28 am
[Mike Most] "No, if you do the math, it is approximately 2.5:1. Uncompressed HD is approx. 1.2 gigabits per second. The 440Mb rate is essentially identical to HDCam SR, and identical to the SR Master format Sony is offering with the F65.
oh... cool, so its 444 Mbs... slightly more beefed up than Prores and matches HDCAM SR.
Mike, where was this published?
hector
Hector Berrebi
prePost Consulting
Chris Conlee
on Nov 7, 2011 at 5:06:44 pm
I saw a press release this morning from Arri saying they're creating a DNxHD recording option for their Alexa camera. In that release they published the 444 codec as 440Mb/sec, if I'm not mistaken.
Chris
