ADVAudioDev: Failed to set DIO audio sample rate
Larry Morales
on Nov 3, 2011 at 9:35:16 pm
Hi all,
I recently upgraded to MC 5.5.3 from 5.5.1 and now am experiencing an issue I've never had.
When I searched it the newest item that came up is from '08. It is, as the subject suggests...
ADVAudioDev" Failed to set DIO audio sample rate.
I'm on a Mac OS 10.6.8, Dual 2.8 Quad Core Intel Xeon with 4GB 800 MHz DDR2.
I'm connected to a Matrox Mini for monitoring purposes.
As of yesterday, everything worked well, today I cannot monitor through the Matrox Mini, I get the spinning Beachball with the Error message and unless I use the 1394 configuration, MC crashes.
It occurs throughout all my projects so it's not really an audio issue.
Any ideas?
tvmambo
