decomposing a sequence/up-ressing n Avid
marc martinez
on Feb 8, 2008 at 6:05:46 pm
Hello,
I am a newbie to the world of working in hd/sd. I was inquiring as to the concept and purpose of "decomposing a sequence" and also the steps to decompose as well as the "upres" procedure in Avid.
Marc
Scott Simmons
Re: decomposing a sequence/up-ressing n Avid
on Feb 11, 2008 at 9:16:46 pm
Decomposing gives you a new sequence with offline media that has had all the clips trimmed to only include the media used in the edit + handles. If you've edited at low resolution you then recapture only the media you need at the online rez.
Life is linear. Edit life.
marc martinez
on Feb 12, 2008 at 8:55:56 pm
thanks Scott!!
MM
