3D Flag Question
COW Forums : Zaxwerks
Albert Campbell
3D Flag Question
on Dec 27, 2018 at 9:33:28 pm
I'm trying to create a flag in 4K but it is very pixelated. My original artwork is very big. Also I try it in vector and it is still very pixelated (even if I'm using Continuesly Raster). Does anyone know how to create flag that is not really pixelated?
Zax Dow
Re: 3D Flag Question
on Dec 28, 2018 at 12:18:43 am
Check your Solid settings. The size of the solid determines the resolution of 3D Flag's canvas. So even if you have a high resolution input image the solid size is what sets the final rendering.
Also make sure you are using the Ray Tracer, not the Open GL renderer to get the best results.
If you are viewing at 25%, do a sanity check and change to 100% to make sure the jaggies aren't an artifact of AE down sampling the image.
-Z
Albert Campbell
on Dec 28, 2018 at 4:14:26 am
Thanks for your help. I'm not sure what I'm doing wrong. I tried those things you are mentioning, but it still looks pixelated at 100%.
https://images.creativecow.net/331164/screenshot2018-12-27at7.36.21pm.png
https://images.creativecow.net/331164/screenshot2018-12-27at7.36.09pm.png
Are there any other things you would recommend? What size of vector file would you use for file ending in 4K?
Zax Dow
on Dec 28, 2018 at 8:43:16 pm
No problem. Send your project file to support at zaxwerks.com and I'll take a look.
Best,
Z
Zax Dow
on Dec 29, 2018 at 9:32:47 am
got the files... you have Lock Flag Image turned on. This setting is preventing your texture from loading completely. Uncheck this setting and you'll see the image turn crystal clear. Once the image has loaded completely you can then lock the flag image and it will render faster when you change frames. However, it's best not to have the image locked during final rendering just in case you get low on RAM and 3D flag doesn't release it.
Hope that helps,
Zax
Albert Campbell
on Jan 31, 2019 at 4:12:56 am
Hello,
I created a flag with an illustrator file.
It is looking pretty pixelated to me still. Are there any other things I could try to make it look less pixelated?
Let me know if you have any other pointers.
Thank you,
Albert
Zax Dow
on Feb 1, 2019 at 8:22:11 am
send the current project to support(at)zaxwerks.com. It's probably something simple. Are you SURE you are using the ray tracer?
