Invigorator: Can you re-edit in demo mode?
COW Forums : Zaxwerks
Ben Sciascia
on Jun 6, 2018 at 10:40:07 pm
Hi There,
While editing, Invigorator/Photoshop crashed but after reopening, I can't seem to edit what I've done.
When I select the layer (with the watermark) and choose the Invigorator plugin, I'm presented with the dialogue box to create something new?
Does this make much sense?
Cheers
Ben
Zax Dow
Re: Invigorator: Can you re-edit in demo mode?
on Jun 7, 2018 at 5:40:18 pm
Hi Ben,
In order to be able to edit your live 3D scene you must create a layer and use the Convert for Smart Filters command on it. Then you can apply 3D Invigorator to that layer and you will see it listed in the Layers panel. To edit the scene double click the name "3D Invigorator" in the layers panel.
By the way, you can do this to any number of layers, letting you have multiple 3D elements all live, in the same Photoshop file.
Hope that helps.
-Zax
Ben Sciascia
on Jun 7, 2018 at 7:11:55 pm
Doh! Thanks heaps, of course it needs to be a smart object. Cheers
Zax Dow
on Jun 7, 2018 at 7:53:14 pm
Ha. No worries.
