3D flag Hi-res texture problem
COW Forums : Zaxwerks
hektor rankov
on Feb 15, 2017 at 10:18:31 pm
Work on 4k animation in After effects and i use 7000*4000 pix texture of USA flag. I have problem. Looks like the texture of low resolution, too pixelated.
http://i.imgur.com/uw7cx7O.jpg
Albert Campbell
Re: 3D flag Hi-res texture problem
on Dec 27, 2018 at 9:23:24 pm
Hello, I'm having that same problem. Did you get an answer to that?
Zax Dow
on Dec 28, 2018 at 12:07:18 am
Check your Solid settings. The size of the solid determines the resolution of 3D Flag's canvas. You are also viewing at 25%, so as a sanity check flip to 100% to make sure the jaggies aren't an artifact of AE down sampling the image.
-Z
hektor rankov
on Feb 6, 2019 at 1:52:52 pm
No. The problem is still there. The Obj is 5000 * 3000. The texture is 7000 * 4200 pixels
Zax Dow
on Feb 28, 2019 at 9:25:49 pm
Check inside the 3D Flag's setup window. In the output panel, make sure the renderer is set to Ray Tracer.
