text color not rendering properly in pro animator 8
COW Forums : Zaxwerks
Nelson May
on May 14, 2015 at 8:44:42 pm
Please see the attachment of what I am trying to produce.
A few years ago someone sent me a tutorial or I found it on making a ratting earth with the "universal studios text. Back then I have AE4 and Zaxwerks 4.5. Many times without success, I have tried to resize my comp from DV to 720. The results are not the same. I was told waxworks would change settings as a plug in to AE, but apparently I come up with multi colored text, and my globe isn't symmetrically round.
It has been so long since I tried this, I wanted to start from the ground up in AE 2015 szx pro animator 8 (plug in)
I seem to remember that you created a comp, went into the sax plug in, wrapped a large picture of the earth around a sphere and added text. Once back in AE, I added a star field and some lens flair.
Anyway, I am all thumbs here and I need an HD version of this comp. Can anyone remember the tutorial or can you help me with steps?
- - - - -Or is this a simply problem with text. If I can get the text to render correctly my problem is solved.
Cheers!
MBP 2.4GHz 4MB RAM, 30"cine, MAC PRO 2.6 8 core 6GB RAM, Mbox, Neumann TLM-103, FCP HD 7. Pro Tools 8, Adobe Creative Suite, Reason 3.0, Macromedia Studio, ProAnimator, HVX200 with Firestore v4.0
Alex Dow
Re: text color not rendering properly in pro animator 8
on Jul 8, 2015 at 10:01:27 pm
Hi Nelson,
Are you saying that your problem is that you can't figure out how to get the text to curl around your world? To get it to curl apply a warp track to your text track. Do this by selecting Track > Warp Track and making the warp amount -25.
Hope this helps.
Cheers,
Alex Dow
Zaxwerks
