Moving Objects in Drawing Mode in ProModeler
COW Forums : Zaxwerks
Charlotte McClung
on Jan 9, 2015 at 1:32:48 pm
Is there anyway to move an object so you can work on the other side than the one facing you - in other words can you make an object 3d without having to resort to lathe?
Edward Wu
Re: Moving Objects in Drawing Mode in ProModeler
on Jan 9, 2015 at 9:00:29 pm
Hi Charlotte,
Please see my other reply, but as mentioned, you would not be able to work on other sides other than the one that is facing you. You would need to work with Lathe Objects or use the Profile Editor to edit the bevel of the object. This may help you to create more interesting shapes. Hope this helps. If you have any additional questions, please let me know.
Best,
Edward
