Moving objects
COW Forums : Zaxwerks
Charlotte McClung
Moving objects
on Jan 9, 2015 at 12:54:30 pm
Is there a way to actually turn an object you are creating around the drawing pane so you just don't have one flat sided object?
Edward Wu
Re: Moving objects
on Jan 9, 2015 at 8:58:40 pm
Hi Charlotte,
Unfortunately, with the Modeling window, you can only draw from one view, which will generate a cookie cutter shape for your objects. However, with that said, you can work with lathe objects or apply different bevels so change the look of your object. By changing the Edge Offset control and the bevel, you can achieve effects where the face appears round or have interesting and intricate bevels.
Hope this helps. If you have any additional questions, please let me know.
Best,
Edward
