ElectricImage Fac export broken Promodeler6
COW Forums : Zaxwerks
Reuben Flounders
on Jan 5, 2015 at 2:33:45 pm
As the title says, fac export is broken on windows, the file opens in a few other apps but in EI its invisible in the viewports or render, x-form scale is 0.0 but scalling up does nothing, someone suggested polygon winding is the issue.
Tested with EI v7 and 9, same deal.
Also fbx export outputs nothing.
Reuben Flounders
Re: ElectricImage Fac export broken Promodeler6
on Jan 5, 2015 at 10:37:39 pm
I forgot to mention, i'm running this on a windows7 system.
Edward Wu
on Jan 7, 2015 at 11:11:54 pm
Hi Reuben,
I sent you an email regarding this issue. Please try the test file that I attached and see if you are having any problems with the file I sent you. Please let me know the results. Thanks!
Best,
Edward
