Shadow pattern
COW Forums : Zaxwerks
Juaquin Sanchez
Shadow pattern
on Aug 19, 2014 at 2:35:34 pm
When I render a single frame I am getting a banding/pattern where there are shadows. Is there a way to fix this?
Edward Wu
Re: Shadow pattern
on Aug 22, 2014 at 9:09:05 pm
Hi Juaquin,
From your descriptions, it sounds like you may be using a low quality Shadow Map. Try going into the Lighting Globals panel and increasing the size of the Shadow Map. After doing this, the shadows should look a lot better.
Hope this helps. If you are still having problems, please send the project file to me at ed@zaxwerks.com and I'll take a look at what you are running into.
Best,
Edward
